You can adjust the amount of fuel going in with AEM, only a tuner can tell you that for sure. Sometimes your injectors are too big to trim the fuel down enough to give you a good idle and low rev driving. This one is for the tuners to answer.
if you mean ? drive to the tuners with the stock injectors and then fit the SR ones there abdul, then yes (as long as you dont run any boost)ok for example if u wired aem in my self, and lefted k11 injectors in, with my turbo set up at psi can I start my car up without the tuner being there wit me, then get a mapper to fit my sr20 injectors in ?
you can easily drive it off boost mate, stani did for months, because it,ll overfuel like mad off boost with the SR injectors and stock map and fuel regyes if I was to wire it all up without sr injectors on, just so I can listen to car and start it up, am gona be driving 2 miles only to mapper
no I mean can I drive it to mapper with k11 injectors on thn when am there I'll change it over for mapping ?
thats what i saidif you mean ? drive to the tuners with the stock injectors and then fit the SR ones there abdul, then yes (as long as you dont run any boost)
gonna be a bit loud mate !yes I got u now frank thanks, can I start or drive car without the elbow and for mapper to do as he said he can weld it, is it safe frank
Disconnecting the charge pipe is easierwill just sound like badass boost leak
That's where common sense suggest go steady. If ypure disconnecting the turbo you're not going far![]()
yes I got things fitted just need hose and pump pump left , am waiting for ed to reply nowazzydot, fit the turbo in like your ready to drive leaving the standard airfilter on and standard injectors, drive to where you need to map the car and fit the injectors there and ripp off the standard airfilter and fit the turbo piping to throttlebody and get the guy to start his magic, its what im gonna do!!! im running the car off boost to get onto the motorway and just fit the injectors and boost pipes when im at the tuning center!! easier... BUT only will do that if my base map isnt running good enough for my setup, i.e. overfueling, underfueling, cutting out etc!!!
Make sure you fit your Walbro Fuelpump in the tank!!!
J
Hijacker.. make your own blogyes I got things fitted just need hose and pump pump left , am waiting for ed to reply now
Am not jacking just replyin bk to alpinaHijacker.. make your own blog![]()
Nuff saidThis has got to be the biggest thread hijack in history
Haha all of u are funny but you lot have helped me a lot thanks to all of youThis has got to be the biggest thread hijack in history
