Could someone explain to me how this would uprate the power? - I find it hard to understand as I thought this was one of the main differences between the 1.0 and 1.3 as they're nearly identical.![]()
if im right then 1.0 pistons will increase compression ratio thus increasing the combustion in the chamber, not sure if its beneficial as ive never done it
main diference is pistons, crank, rods and cams
the 1.0 pistons fit a treat, and raise the compression (giving you more power)![]()
i have sort of done researh on this as a cheap way of tuning a cg13.
the 1.0 pistons are flat top and the 1.3 pistons are dished.
the 1.0 rods are a diffrent legnth to the 1.3s do to a diffrent crank.
iirc the 1.0 pistons are smaller the 1.3's.
if you was to fit the 1.0 pistons into a 1.3, ither there wouldnt be engough compression, or the pistons would hit the head lol.
and you would beable to fit the rods, pistons in a 1.3 ither due to the crank beeeing diffrent...
therefor it would need custom rods i think?
best bet is to a) stick 1.3 cams in and be done (a nice gian
b) stick in a 1.3
c) spend alot of money lol
dan
except that it does make it sound slightly more simple than it isi would recormend honeing the bores and you will need new rings and all the kit to rebuild the engine.
So all I would need is the piston heads from the CG10 and install them on the CG13 Rods?
What are the power gains for this? What is the difference in compression?
Will the rise in compression pose any damage to the engine or affect it in the long run?
One more thing: The 1.0 pistons are FLAT, giving a 10cc differende between the 1.0 and 1.3 piston. But also than the cr. will be 11,8:1 Also the engine will be no 1275cc, but 1235cc. This less volume will also infect the power gain I assume. (perhaps this clears why my engine is NOT running lean with the original injectors??)
Hmm Young Nav was right! Or do we make a mistake calculating these numbers??
gr Chrismo
All these figures i have worked out myself
You are right again.....the stroke remains the same, so the volume too. But why is there almost no power gain noticeable in my CG13, with 1.0 pistons, NME (Peter V) cams and a flowed head? I don't get it!
is the left the 1.0 piston?
Giving some more info about my mods: I have the oem intake, including airbox. And have a custom made exhause manifold, with I think, a bit too small pipes (28mm inside).
If above should be no problem, I truely start to believe the port-grinding I did is the problem! Why is it possible to run 12:1 at full throttle with standard injectors?
gr Chrismo
why doesnt someone bloody do it and then we'll have answers?? or are we all scared to do so unlike me![]()
Swiper has done it previously?
If you fitted 1 litre pistons and it reduced the compression could you not bolt up a turbo and give it the boost.
