It can be done - its just going to cost you a bit more and require a bit more thought into the placement and how the IC will be secured.
On the micra it may even require modification of the aircon pipes (which is possible, just can be expensive as custom aluminum pipeage is required, and of course the system will need to be regassed when you remove one of the pipes...)
