cisco
» CMF MemberThis particular rattle was the bain of my life for a while..
Tonight I cracked and dived into the rear of the car to play around with the hatch determined to fix it.
Turns out it was the latch thing in the hatch lock mechanism clunking and sliding against the metal loop that it latches over.
First I adjusted the metal latch loop that is bolted into the back of the car (the bit that the hatch latches onto). This needed to be lowered a fraction so that the boot was a tighter fit when shut. This reduced the amount of movement and amount of chance it had to move and rattle. But this did not remove the rattle.
Then I simply wrapped a couple of layers of electrical tape around the same loop thing. This meant that when the latch engaged over it, it was only rubbing on plastic and not metal.
GONE GONE GONE!!!
Just beautiful. I went for a drive and was over the moon. How could life be without that former rattle! This is a new car!!! YEAH YEAH YEAH. Damn those rattles crack me. Slowly but surely I'm removing them all.
I'll see how long the tape lasts, and if it wears away eventually I know to just fix it with something more permanent.
Still a couple of other rattles to fix of course. But I promise I will eventually have a rattle free vehicle. Then I will be so proud.
GONE GONE GONE!!!
