Wiring super S cluster K11
Craig
Unofficial Member (Gold)
I know that a couple of people have done this before (Pete...) I have (I think) a 1l loon, but the above dials. The rev counter, fuel, temp gauges do not work. Do people know which wires I need to swap tp get this all to work properly.
For starters, which plug do I need to send the tacho feed from the ECU to?
Craig
yer i have done this, my pre facelift with super s dials, it should all plug and play except tacho, for that tap int the blue wire on the dizzy, then the wire goes into the blue and black i think it is ill look 2mz then put a simple diagram up i know this works.
I'm fine with the tacho feed (going to go from the ECU) but which pin do I need to put it into? I have no blue/black.
Frank, you are a beaut. What concerns me is, though, I compared the wiring I have and the wiring from the SS loom and the blue/black plugs go into the same holes, I've tried tracing it back to the ECU, but didn't know where pin 2 was!
Craig
