Wiper relay
curtis
If you have a LS model etc you only get the 2 settings of speed
But if you have a newer one or top trim type, you get intermittent as well
Just wondering, apart from the control stalk, would it only need the relay changing to make it have the 3 settings?
Thanks Curtis
im not sure if all wiring looms have the required "intermittent wire" already in the loom or not (for transporting the permenant INT signal from the stalk to the intermittent relay)
