sammyboi
MicraMachinePower...
Ok, so you need to bear in mind that this is still a work in progress, bodywork needs some TLC, mainly from the badger hit months ago.
So here the spec:
Nissan Micra 1.3 Super S
..4-2-1 Janspeed Mani
..Janspeed cat back competition exhaust
..Raceworx Short Shifter
..Bilstein Shocks & -50mm lowering springs
..Wide Arch smoothed in (still some damage from badger hit)
..Nismo Spoiler (with 3rd bake light)
..BCW Deep Dish Wheels (14x8.5 front, 14x9.5 rear)
..Nismo Engine Mounts
..E-Tech Strut Brace
..Whiteline Panhard Rod
..Stripped out rear with false floor
..Peter Vaughan Built Engine (stamped with his build number) which consists of:
-Group A Rally Cams 773 Spec
-Competition Forged Pistons
-Professionally Modified Gas flowed Cylinder Head
-Janspeed Competition Grp A Exhaust Manifold
-JUN 3.6kg Flywheel
-Helix 200mm Racing Clutch Assembly
MOT till End May 2010
TAX till End December 2009
All bits new add up to about £4600, looking for £2300ish. Might break for bits if i get a good amount of interest in various parts...
Pics below are what it looked like at ISTS and when i sprayed the wheels blue, will get some pics up of it now on wednesday! Just needs some fibreglassing done on the drivers arch then smothing. Rear arches are still there under the wide ones, fronts have been cut away.
Thanks for looking!
So here the spec:
-JUN 3.6kg Flywheel
Thanks for looking!
