Winscreen wiper on driver's side broken - help !!
Hi everyone,
My fiance's K11's windscreen wiper no longer works on the driver's side only (it doesn't move at all and I can move the wiper by hand without any resistance at all)..
Does anyone know how to access the windscreen wiper mechanism and what bits may need to be replaced?
Thanks everyone in advance.
There is a shaft that links the two parts on the ebay link.
On the end of the black part you will see a ball.
There are 'cups' on the end of the shaft that the balls pop into.
One will have popped off.
If the cups have worn, a brand new shaft from Nissan should be less than £15.
If you look on NPOC.co.uk, there is a guide in the how-to section showing how to take apart. Should be very similar to the K11.
