Will these fit in my K11?
k11's will take a 6.5" speaker no problems, only problem is the mounting depth which you are limited to 54mm
heres the spec of the speakers,cant seem to see the depth size:
Max Power Rating (Watts): 240
RMS Power Rating (Watts): 70
Compliance (Cms): 578.4
Cone Area (Sd): 11.9
D.C. Coil Resistance (Re): 3.6
Electrical Q (Qes): 0.77
Force Factor (Bl): 4.5
Free Air Resonance (Fs): 56
Frequency Response: 53Hz - 22kHz
Impedance (Nominal): 4
Mechanical Excursion (mm): 12
Mechanical Q (Qms): 3.4
Sensitivity (dB) (1W/1M): 86
Total Loudspeaker Q (Qts): 0.62
Magnet Structure (Oz): 13.5
couldnt find any mounting depth info. on the net myself. Would be best to pop down to halfords and look at the box or ask them.
