where can i get coilovers
Nobody makes coilovers for the K10. You'd have to get some for a different car and modify the car to suit them.
AMY was selling some on ebay, not sure if they have ended or not, type "micra k10" into ebay and see what comes up
want to upgrade my suspension i got weight issues
i have a ga15de in my k10
and my springs are crying
i heard the civic springs work but which year all i think its the eg8
next problem i am from the Caribbean
Umar has done a 1.5 conversion, i'm assuming it's the same block. Got any photos of your one? You should set up your own blog if you haven't done so already.
Arnold
got a question 4 u
that conversion with the sr20 did u cut axles and what springs u use
and are u using manual or transmission on the sr20
i am thinking about doing a transplant but with the ca20det what u think which one will be a better fit without problems
The car will have Pulsar Coilovers, because it has a pulsar floor pan, including front and rear suspension. The whole lot's basically been cut out and welded into my Micra. The front and rear axles are transferred over too. It will be using a manual gearbox.
You could do a SR20 conversion, although one has never really been done successfully before on a K10. I'd stay with your CG15 if I were you and just resolve your suspension issue.
