where can i buy a carb gasket for my ma12 inlet? also other parets needed
jamieccc
as above does anybody know?
i need a carb gasket for an ma10/12 inlet, also i need the metal brake pad guide things which are on the calipers if anybodys got them?
cheers jamie
Pad runners from halfords (lots of agressive corrosion removal required prior to fitting coz thay are TIGHT) £3?
Gaskets from Nissan main dealer:-( £6?..and a long wait if theres none in stock
you shold get the gasket from any motor factors, you get one in a head set but there like £20, but you get every gasket for the whole head inc the head gasketso not really that bad.
I bought an inlet manifold gaskit from nissan dealers in febuary this year; £9.50 inc. VAT.
Thermostat housing gaskit (and that's the complete housing that the distributor slots into not the little triangle piece); £4.49
Rocker cover gaskit; £7.97
Timing Belt; £26.46
Everthing arrived the very next day.
