Wheel spacers...
Just a quick one... What are the thinnest wheel spacers you can get & would I need to extend my studs at all?
This is in relation to my Rostyles which with a bit of luck should be going on next week... Just still concerned with them being lug centric rather than hub centric...
You want at least the nuts filled with thread - preferably a little bit of protrusion of the stud through the nut. 3mm is also the thinnest I've seen.
Yeah, 3mm is thinnest I could find... Prob is I'm using closed lugs but can always put standard nuts on first to check I guess?
