Wheel Nut Question
I am looking to get some alloys for my car, i have priced the locking wheel nuts could i put 1 locking nut on each wheel and use the original 3 nuts off the four spoke SR wheels for the rest or NOT???
Any help would be great
:k11green:
nope.... the origonal wheel nuts will not have the same pitch diameter (bottom of the wheel nut hole) as the new alloys..... you need to use the correct fitting kit that came with the wheels or even go and get a fitting kit from an alloy wheel supplier.
if you fit them with the standard wheels nuts you can create pressure points on the nuts and even snap them off.....
but yea, use one locking nut and three wheel nuts,.
wolfrace wheels
Cheers for the help on the above
I'm looking on ebay to find some locking nuts does it matter if they are not wolfrace nuts?
What size are the wheel nuts I require that fit onto the micra threads?
Quick response wud be great.
