In that case you have no need to check clearance with the Corsa stuff, as you will be cutting off the standard steel arches anyway to give clearance, and you'll be able to make anything fit.
Remember fitting such off-set wheels does completely alter the front scrub-radius and can have an adverse effect on the steering and handling.
