Paul Smith Site Supporter May 31, 2009 #1 Basically i am after a oil pressure T piece but i need to know what size thread the cg13 engine uses so i get the right size? How do you measure this? Thanks Paul
frank Club Member May 31, 2009 #4 1/8 npt is 27 tpi and .405" dia 1/8 bsp is 28 tpi and .383" dia edit and mine measures .390" dia lol
OP OP Paul Smith Site Supporter May 31, 2009 #5 its to go under the inlet maifold where the oil pressure sensor plumbs in, Thank you for the sizes
Antony Ex. Club Member Jun 1, 2009 #6 its none of these.. its 1.8thBSP tapered. remember its a tapered fit or you could crack your block fitting it in.
Stani1029 Club Member Jun 2, 2009 #7 you say your using the a feed from the oil pressure switch, let me know how you get on as i used this and have now went back to the plug on the front of the head.
