what dvd player to get??
Depending on your budget a second hand ripspeed all in one unit will do the job for under a ton. Do you research however as the early model are known to be as useful as chocolate fireguards.
http://cgi.ebay.co.uk/Ripspeed-In-c...66:2|39:1|72:1689|240:1318|301:1|293:1|294:50
Also need to note that you will need to modify your dash or the resting position of your headunit if you go with this option as the dash is in the way of the flip out screen.
Fitting something like this maybe easier, you will need to modify the centre console slightly or buy a JDM version and it will fit with minimal troubles.
http://cgi.ebay.co.uk/DOUBLE-DIN-CA...66:2|39:1|72:1683|240:1308|301:1|293:1|294:50
