That was for a 206, no ?
Why would I need an electomagnetic one with an oil burner (never heard of a dump valve having an oil burner or needing one when its just air that goes in) ? when it already has a dump valve that isn't electromagnetic ?
The difference between after market blow of valves and the factory installed generally is the after market have a small trumpet opening to vent the sound, they work in the exact same way at the basic level, a spring holds the seal until back pressure of boost from the turbo reaches a certain point that cause the spring to give way to vent the excess air and keep the turbo spinning.
The only reason to use proper electromagnetic blow valves to my understanding is to "tune" the blow off valve, blow off duration etc which can all be adjusted on the valve itself with the spring tension.
