Finished doing my 1.3 conversion yesterday just having a few teaving problems
Chav.Nothing yet but picked this up
not starting ?Finished doing my 1.3 conversion yesterday just having a few teaving problems
Hi Frank no it's starts and runs but I can't work out the hose layouts around the fuel filter and carbon canisternot starting ?
Chav.
Hi mate been very busy so haven't had time to post lately but now things are getting back to normal so will be posting more! I have been using the Cab a lot at weekends when the weather is dry never take her out in the wet only dry miles! B-)Where have you been? I've missed seeing this weekly![]()
Sod that for a lark - best of luck (!)Well got the K11 loom today, there is a lot more to it then i first thought, going to make a start on it tomorrow and see how it goes. I've got a month to get it working before JAE so i'll see how it goes haha
Update Max....the fella never turned up to buy the car, so I've taxed her again.Dislike!
Hope you're going to stick around on the forums.
(and you'll direct the new owner here)
Sorry this was the format for sigs everyone used on the previous forum I was on. Adjusted just for you
'94 k11 dot 1.0, McGill Motorsport steering wheel, Mountney steering wheel boss kit, Side exit peashooter exhaust, Lowered on Kilen springs, Renault 5 GT turbo turbine wheels 13", Nankang NS2R semi slicks on the front, Whiteline front arb (not fitted), Idle control systems removed, Intake trumpet on throttle body, Micra SR clocks (green), GT15 turbo to be fitted (waiting on rrfpr)
Bit of grease on the slider (?)I've been on here a year todayAnd it seems my car has decided to welcome the occasion, just over 4 months ago I done front discs, pads and a N/S caliper, Yesterday I decided to check them for the first time in two months, Much to my dismay the passenger side pads are nearly metal to metal, Somethings not right here, because the other side still has over 3 quarters left on the pads, We've been throwing ideas around at work and come to the conclusion it is either a faulty caliper, or a buggered Flexi pipe, any ideas?
Looking well dudeThat's better. (Only temp fitted with scrappy clamps)
Ordered a lovely £5 eBay hood scoop too. Thinking of maybe fitting a small fan underneath the intercooler to draw heat away from it, especially when stationary. We'll see.
Also had to change the tie rod end which wasn't playing ball
And then come down to Cornwall - and do mine will yaGave mine a thorough clean on the outside, peeled all the weather strips cleaned it all, waxed and put all plastic/rubber bits back.
Also gave a good clean in the engine bay after finally managing to undo a rusted screw on the throttle cable (needed adjusting as the throttle had no response for 2-3 inches of pedal travel - very loose). Had to file down the sides on the adjustment part so I could clamp my vise grips securely without them slipping on the round surface, the top threads are now unusable, but I will never use them anyway.
Adjusted the clutch pedal height and cable.
Now have amazing clutch and throttle response with a very shinny car
Tomorrow will clean up the interior and then next weekend will do a full service - oil, filters, sparks, PAS flush, belts, etc.
And then come down to Cornwall - and do mine will ya![]()
You could cover them with chrome covers like @Andy5077Well little old red went for scrap value but there you go. Couldn't keep 3 cars here so she's gone. Now we have a 2001 coil pack Vibe 1.0l. Needs nothing at the moment and 11months MOT although there was no RH dip beam when I picked it up?! What can be done to replace the black bumper infiltrate bits? These are terribly grey?
Peanut butter (Not the crunchy kind) or a heat gun, heat guns cleaner![]()
You can take them off, but you risk damaging them.Well little old red went for scrap value but there you go. Couldn't keep 3 cars here so she's gone. Now we have a 2001 coil pack Vibe 1.0l. Needs nothing at the moment and 11months MOT although there was no RH dip beam when I picked
We don't peanut butter but the Mrs has a heatgun for crafting. Do I need to take them black bits off the bumber first?
Mines the same, not sure if its the tach or the signalI took off the front wings and slapped underseal all over the inner wings and the inside of the wings as well, also fitted an external tacho (2002 coil pack) but the tacho seems ok ish but the engine sound does not seem to mirror what the tach needle is doing.
It ticks over fine but when you rev the engine it just seems slow?
Rct
I have ordered a blutooth obd2 thingy and will test it with the nissan app.Mines the same, not sure if its the tach or the signal
Try torque for android, its pretty goodI have ordered a blutooth obd2 thingy and will test it with the nissan app.
When it arrives I will post back my findings.
Rct
Obd2 bluetooth has turned up, just can't get to it till after tea tonight, dam I can't wait to play...Try torque for android, its pretty good
