That's a bit OCD there buddy....most just vacuum the booger, LOLThings got serious with the Micra today. I had to use a bucket of soapy water and a hose pipe to clean the interior. Well worth it though![]()
Around where?Blimey, that would be a £40 note here.
Around where?
Was thinking to buy the spring compressors and a bit of diy but.. don't wanna do anything wrong.
Looks like you been keeping chickens in there did you find any eggs lol! B-)When i looked like this i didn't really have much of an option, the hoover did bugger all haha
Do you lose points, or penalties if you hit a cone (?)Updated the blog www.mattendean.co.uk
LOLLuckily not, or else id be shagged![]()
Will be interested in your alignment numbers Dave![]()
Not at 90 mph mate, she'll drink fuel like every other car then.Working away this week next to Cardiff.
Driven the 1.3 Si from London and managed to do almost 300miles out of full tank. Only did 75-90 on my way..so the question is... doesn't it eat too much fuel???
Sent from my SM-G900F using Micra Sports Club mobile app
I have been exploring quite a lot in the work van. LLantrisant and Merthyr Tydvfil Lovely views !Down my way thenThere are some decent roads up in the South Wales valleys so it's deffo worth going for a bit of an explore
As you say starting off with a baseline is always a good start. Makes a big difference in itself.So will I. It's all very sub-optimal at the moment. First I need to start with a square car and go from there.
Both castor and camber are unequal. I forget castor but camber is about -1deg on one side and -1.5deg on the other. Bump steer is also sub-optimal and needs work.
None of those point will be promoting front end stability under heavy acceleration. While it will always be subject to FWD limitations I'm confident it can be improved substantially over where we are now.
That thing is a monsterFully ducted intake complete.
and a revised front end...
Holy c**p Batman drives a MicraView attachment 48206 Filled her up for the trip back to London.
Bye Bye Cardiff
Signed,
Black Knight
Well..he might drive yours as it's in better nick than mineHoly c**p Batman drives a Micra
External stealth mods completeView attachment 48215
Stock Micra fronts have 2 12mm mounting to chassis iirc and the bottom bolts are 15 or 17mm. Then the top mount nut I don't rememberSo..going to buy a pair of spring compressors..the lowering job will be a diy as the quotes i got from different mechanics average at 150£ ..too much!
Anyone knows what size are the bolts that i need to undo to take the shocks out? Thinking to buy a full socket set too.![]()
And all to be done this Saturday. I'll open a blog to put all these updates so won't fill up this section all the time.
That and the Saab conversion isn't new. I've seen one other in the Netherlands. That looked as understeer prone too.I don't fear about the copy they will fear how hard it is, u need to make custom subframe on the rear no Micra has one I made mines, u need custom cross member or engine will never go in
that's better losing those teeth grillz
stealth mode ftw
I've done plenty of research into rack angle vs bump steer on these cars Dave, if I'm any help.It took a lot of faffing but I was determined to retain as much of the OEM bumper cutouts as possible. I've always liked the OEM look of the K11 so I don't stray from it much.
Next up is to give the steering a dose of staring at. One of the rod ends sounds like it's got a knock, I don't know if James upgraded the rack bushes and the rod arms need re-positioning anyway as they're not optimal for the set ride height.
Also devising a bump steer kit with relative ease also
It's confirmed by Nissan UK my Rouge 5 is one of the last ever K11 1.4SE+ to be built in the uk, I ordered some parts from a Nissan dealership and gave them the VIN number and they confirmed she was built in the last week in November 2002. She was ordered by our local Nissan dealership and registered in Feb 2003 same time they were selling the K12's lol! B-)
Here's a pic of one of the last of the UK built K11's.
Got it to 100MPH. It's a 1.0.
Managed to lower my front. 6 hours hassle because i didn't have tools. And it was too late to start on the back. But drove 30 miles and feels alright. How hard do the the back now..10h???
It took me 10 minuets todayManaged to lower my front. 6 hours hassle because i didn't have tools. And it was too late to start on the back. But drove 30 miles and feels alright. How hard do the the back now..10h???
I had no proper tools. The top not that holds that "hat" over the spring was very stubborn.It took me 10 minuets today![]()
