One of the trims fell off my car yesterday, so that means all of them must come off. What colour should I paint my steels (car is AJ4 red)?
Go cream, bit different to the standard white
Transparent... take it to the next level....
Hmmm now thats an idea , take a picture of the area without the wheel on then get the section the wheel would cover transferred to the wheel![]()
Cloaked wheels???
Whoa.
Mind. Blown.
transparent, as in coating, would just be a straight laquered wheel.
a completely transparent wheel, as in just seeing the brakes/hub magically hover within the tyre/rim, can already be done with any open-spoked wheel via the wagon-wheel effect.
getting the same effect while stationary, you'd either need to make the wheels out of transparent material thats strong/tough enough (glass, perspex, diamond, transparent aluminium) or keep the wheels spinning while the vehicle's stationary (chassis lifted off floor, 4wd burnout, roller wheel dolleys)
I think he was joking Paul
My dreams just got technical , i just had some crazy ass harry potter stuff in my mind![]()
no one cares, you cannot see your dream, #'projectfailModified my topmounts to give me 20mm more height, and completed reassembling the GA coolant bits (30mm core plug is perfect and looks pretty good too).
Need to do some small revisions to topmounts before I show but the handling is much improved.
who cares, whats at the wheels.Put mine on the rolling road at college and i have gained 15bhp at the crank some how
throttle body resetting...butterfly..idle valve
..clean out sensor...remove View attachment 28973
see that screw in the idle screw hole it is a interior panel fits exact in the thread hole cause i lost one
what you want 1l for?
50mm springs?Lowered mine![]()
50mm springs?
Oh and corsa shocks on the rear![]()
You like work.Picked up the old girl, and enjoyed a good thrash back
- New sills both sides, turns out there were very rotten
- WRC Style sill stand mounts fitted (stands arrived at work too)
- Painted the new sills in body matching AJ4 - couple of quick coats this evening when i got home.
I didn't do the welding, i can weld but i dont' trust myself on safety critical stuff. The garage spent a long time sorting out the sills and mounts.You like work.![]()
Dyno results from yesterday![]()
Daaaayyyyyyuuuummmm I want these!
apparently they are, I remember a video with a car drifting with wheels like that to prove its strongThey don't look very strong
Erm, 29.5kW transmission loss?!? That's not right, you should be seeing half that.
