Installed the new pedal box, hooked up both master cylinders and bias bar. Then found out the dash adjuster was for a 3/8 bias bar instead of the 7/16 I have.
D'OH >.<
So does yours....![]()
Apply cold water to that burn McMicra![]()
I have corners and speed bumps and backroads to take.
Eh scott? Bit embarrassing my cars faster because you get stuck on grains of sand![]()
That is NOT an excuse for not having moar lows, I'm extremely disappointed in you.I have corners and speed bumps and backroads to take.
Wait till you drive a car that's on its' arse.That is NOT an excuse for not having moar lows, I'm extremely disappointed in you.
*Hides his standard ride hight facelift*
That makes a change from people just leaving it at 'your argument is invalid'Wait till you drive a car that's on its' arse.
Until then, your opinion is invalid![]()
A d reliability manDon't get me wrong, mega lows looks sweet ass, but practicality wins for me so 60mm is lowest I intend to go![]()
Was a pleasure to meet youWdid? Visited Mr h701 and dropped off a turbo... Secretive schemes...also saw his rally monster and the nissanburu frankenstein
Your not the only one buddy I was trying to fix the body work and it interrupted me too!de-badged the back and got started on the bumpstrips before the weather rudely interrupted me.![]()
I started like this!!Don't get me wrong, mega lows looks sweet ass, but practicality wins for me so 60mm is lowest I intend to go![]()
So secretive!Wdid? Visited Mr h701 and dropped off a turbo... Secretive schemes...also saw his rally monster and the nissanburu frankenstein
Is the rear beam weak then? I always thought it was solid as anything, I remember frank struggling to bend it with a 20T bottle jack and chain...Collected her from Matt Humphris, who has welded in his rear beam strengthening kit, also he replaced the front top mounts which needed doing, all for a very good deal. Top Bloke and one of Wales Rally GB sponsors
Oh and very much enjoyed the blast across the lanes coming home![]()
hmmm, possible camber adjustments thenThey do bend around the curves where the beam bends up and around for the rear hubs.
Yeah, maybe make up a jig out of a steelie which bolts to the hub...hmmm, possible camber adjustments theni was trying to bend the wrong area then
i was thinking 2 steelies and chain ed, and a nudge from a sledge hammer when tensionedYeah, maybe make up a jig out of a steelie which bolts to the hub...
I thought that but which ever is weaker might get more camber. I guess if a sledge hammer was involved then it may be more controlled.i was thinking 2 steelies and chain ed, and a nudge from a sledge hammer when tensioned![]()
i ton of chain tension would probably flex the tops in about 10mm ed, but they would just spring back, the sledge would deter that returnI thought that but which ever is weaker might get more camber. I guess if a sledge hammer was involved then it may be more controlled.
Joys of fancy cars eh
It will be interesting to see how you balance is effected on a short wheel based carYeah, pros and cons for all walks of life. Looking forward to the brakes turning up that those M/C will be feeding though, they're something else![]()
nothing but the best eh davethey're something else![]()
nothing but the best eh daveand pics or ban!
how i feel for my theory tomorrow:
5th try lucky aye?
5th try lucky aye?
Something that I did in hazard perception click as soon as you see the hazard then leave like 2 maybe 3 seconds and click for it again might workbut good luck anyway
Worked for me.
I used to click too soon and got 0/5 so I made sure I clicked again a second or so later to make sure I got something
Worked for me.
It's rubbish most people I know that have passed see the hazard before the program thinks you should see it
I passed first time 66 points with 44 needing to pass. I didn't see the challenge. Mostly common sense..
Keep postitive buddy best of luck!!!i lack common sense
I'm not even sure what it is.i lack common sense
WDID?
Got 47.0 miles from £10
= 28.7 MPG
What causes poor fuel consumption?
Me driving I normally get 60 or so so im a little concerned at 47 =/
Good luck Chris!
Clodo
X
