Now that's what I call modding.Not done anything but I spotted this on the way to work
http://s22.postimg.org/xzu3vh8gh/image.jpg
Going back to greyGrey definitely, it visually lowers the car
INB4 Max moans at me :L
Anyhoo test fitting stuck em on roughly with double sided foam tape
Gonna be different with jap lights and jap boot and they will be coded to match the car
[/IMG]
If you feel the need to get rid of the top spoiler, Let me know![]()
Those replica's are on ebay if you fancy one bud![]()
its a replica I have manneeds tidied up quick sand and paint and sorted, doesn't come with the normal spoiler bolts you have to screw bolts into it then put it through and tighten up with a nut, but im tiger sealing aswell
If you feel you need to sell the mid spoiler send me a pm !
no spare wheel scott ?Discovered my split valve is indeed a cracked weld. Awaiting recovery.
No jack or tools ..no spare wheel scott![]()
same appliesNo jack or tools ..
Annoyingly I usually carry every tool !same applies![]()
same applies![]()
What mid spoiler is that?
Yeah, I started Toms car with my key, they do wear pretty badly...Wdidt? Went to go to work..... keys in ignition, cranked mildred over...... nothing atallmad panic as I was running late for work.... so had to bum a lift with mumma bear
a 5 min drive for me...... took 20 minutes *rollseyes* devastating to not see my car in the car park
thankfully the wonderful @micrapro came to my rescue
while I was at work he very kindly changed the starter motor for me as this was what I thought was wrong...... unfortunatly not..... think the ignition barrel has worn to much
I can turn my car on and take the key out the ignition while the car still runs..... not good!
One of the girls from work can unlock mine with her key lolWait no, I unlocked it, same principle though!
Immobiliser to get past tooIn that case ill just nick Milliex
Here's how she sits atm
Got camber?
Sad day.
Can anyone help with this? @frank
The lambda and HC reading are fine its just the CO reading is to high
