I wash my GX today. I use jet wash to blast all these under arches and underneath. A lot of dirts came out so it's time to put underbody sealant soon.![]()
Plug in and play then, happy days - I'll have a go at that. Cheers HuggyDoes it have a digital mile counter or mechanical one? If it's digital it's plug and play iirc
r-reg-sr said:You gonna do the oil mix style like frank ?
Btw summer is almost finish now. Autumn and winter, I am ready to fight these seasons.![]()
r-reg-sr said:Ahh yes you to have noted the start of the long dark mouldy nights. how many cans would you youse under?
Maybe 2 or 3 cans. I don't have time to do it over around fuel tank and axle. They are getting rust bit by bit. -_-
Luck of the Irish or what !!!!Changed H4 bulb plug. As a result:
1) central lock start working
2) warning signal is back (when door is open and lights on)
3) beam light is very bright
View attachment 25379 View attachment 25380
Ah well, maybe not so lucky - 1 out of 4 ain't badalso side repeaters plug is melted as well. Do you know where I can get it? (at Halfords only H4)
...Should we be worried that you're going to become a picture posting whore?Posted this - because I can, only practising.
You have to look at all the roses in the garden, to remember you married the best one![]()
...just because you can LOL
WDIDT?... Called up my insurer...to change my details from Unemployed...to Employed...
...before I even told them my policy number, and everything, I explained that I knew it should go down by about £50
...but I'd bet they'd want about £25 back in the form of an "admin fee" <_<
...anyway...went through the usual,
Name:
Date of Birth:
...Policy #
...car Registration #
...then we spent 5 minutes picking a bloody Job title for me *facepalm*
...then...
...finally...
they got to the bit I'd been waiting for...
...I'm getting £68 refund on my premium...
Bargain!!!
(makes my annual premium about £240)
obviously I'll be double checking my bank![]()
Yea it looks like mintex drilled and grove brake discs.
It is.![]()
Cube maybe?Well, not Mintex!
They are indeed Brembo.
I decided to measure up. These are:
234mm across.
4x100mm
CB of smidge under 60mm.
12mm thick
The side of the disc says
"8513B 2FA MIN.TH 10MM Y0 BREMBO"
I can't find anywhere that sells Micra K11 grooved and drilled Brembo. Are there any other Nissan's with fitment and disc size the exact same as a K11?
I thought so too.This is so weird though. They are looks same as u got now.
1.0
http://item.mobileweb.ebay.co.uk/viewitem?sbk=1&nav=SEARCH&itemId=251005061570
1.3
http://item.mobileweb.ebay.co.uk/viewitem?sbk=1&nav=SEARCH&itemId=270922687729
Softer front springs should see your turn in improveThought about the set up for tarmac stages, started but gave up.....
Understeers a bit much for my liking, and the bum is very settled. Thicker rear anti roll bar? What else?
Well, not Mintex!
234mm across.
4x100mm
12mm thick
NooOr softening damping?
Noo
Do you have a way of altering the damping?
