WDID ? coded the wheels
What i done? Not alot fitted some exeon bumbs at jae lols####ed with pa system goin what more!
i thought you were gonna say WDIDTMMT ? "slept in it because my tent blew away" will :grinning:
won show and shine :wasntme::laugh::blush: and drove home lol....
used less petol this time than when i went to RRG and i done more miles this time and good few coldstarts more too!
nice one willzzzz (Y)
WDID ? cut a notch further down the clutch arm for better launch control at the pod
What's this done mate? Made the stroke shorter? Or clutch softer?
i always thought the cable clutch is too light, iam used to hydraulic stuff lol. have you tested it yet? i may have to copy![]()
What colour is your SR dude??
frank boy :grinning: slightly more force/wear on the cable ?
headlight wash/wipe system :grinning: WDID ? bought some corsa coilies from my local friendly scrapyardremoved some dead weight that never worked in the first place...
guess what it is! if you guess right ill sell these 100% original parts to you for 1€
headlight wash/wipe system :grinning: WDID ? bought some corsa coilies from my local friendly scrapyard![]()
i dare,nt go any lower will, i,ll test them out for a week or two, and robb might want themcool dude! join the scraaaaape club!
they do look good though! stiffer probably too!
slammage my butt fwn its a 4x4 now with these corsa coilies on (when you use the whole corsa topmount, and slot the 2 boltholes)Get them on! (Y)
:grinning: you got the helper spring on, whats it helping with
nah, i took it off the one that is fitted to the car z(and then wound the collars up to about 2mm of preload)
you recon they differ from the one's we've bought on the net?
my springs 68 mm's from the botom measuring point we used(bottom mount top edge)
its because i used the whole corsa topmount mateyou end up with a lot more height, and its the same kit as yours (200-50 on the mainspring, and 100-20 on the helper)
i think i prefer the factory corsa mount, proper ballbearing thrust bearing (Y)
frank id put the matiz back on lol
i run about 50mm slack in my springs. no helper springs. i have about 10mm of bump before it hits the stopper. its awesome!!
frank id put the matiz back on lol i find my ebay coilovers to be a bit bouncy, almost to the point its dangerous. i managed to get bilstein mx5 rear shocks which are amazing but the front end scares me.
i need to some gaz or spax front coilies :glare:
