h701micra
Deactivated Account
I'm planning on a visit to cadwell before the winter. Then back in its winter boxi will mate, a couple of trackdays are looming tho eh (donny and prescott) then its back to a little daily mule for the winter![]()
Enuo said:Because Japfest
hehIs that mower the next turbo project frank??![]()
I love self tappers, right up there with cable ties and duct tapeheh
i,ve just this minute had to screw some self tappers into the plastic ratchet cogs actually ade, and then dremel the head into a notch shape, they were slipping quite bad this morning
Wdid drove my focus zetec to work n back n thought how good it feels to get to 90 with ease compared to the 0-30 in 2 weeks in the 1.0l k11 I had![]()
Unless your in a rush for the bogBut there's no need to do 90 on public roads
ghetto ftw eh mateI love self tappers, right up there with cable ties and duct tape![]()
Hell yeah!ghetto ftw eh mate![]()
Started prepping it for jae![]()
Removeit'll look really clean then just Finnish it off
Bumper looks awesome!
Chloe
X
Heyaa everyoneneed a slight bit of help apologies in advance this is the wrong place to post. But cant figure out how to make new threads.... Damn Smart phones!... Bring back the Nokia's
Does anyone know what the offset if there is any of the original k11 pre-facelift 13" steelies.
Sorry to be a pain
Thanks all![]()
Chloe X
As much as that45 innit
Well you got 37, 38 and 45.. take your pickThankyou very much everyonehelp is muchly appreciated!
45 innit
Definitely wanna be hubcentric that wide, my 10mm ones on the rear of my car wobble like crazy at high speed, wider ones will just be worse!Ok thenI think I'll go 32 mm just wanna give her a bit of poke
When I ran 32's for a short while, as the spacers were universal I centred them with spigot rings. The wheels centred fine with the taper on the nuts. No balance/vibration issuesDefinitely wanna be hubcentric that wide, my 10mm ones on the rear of my car wobble like crazy at high speed, wider ones will just be worse!
I'll see about spigots for mine then, anything over 105 I get alarming vibration atm...
Edit: over 65.![]()
Is that the limit of the stock ecu?WDIDT ?
cut open a wastegate actuator, to fit a softer spring(arrowed is the rubber diaphram)
i used the spring on the left in the end (3 coils cut) max boost now set @ 4psi precisely
dunnoIs that the limit of the stock ecu?
