Battery shorts out over 24 hours - 1 amp leakage current(!) traced to courtesy lamp - but this also powers the immobiliser (red LED on dash). Took out fuse - leakage drain is now 0.1A, but drops to almost 0 after 10 sec. Traced this to a fuse labelled "refer" - what does this do?
Car still drains battery!
Recharged battery.
Have now discovered that the b####y thing won't turn over - tries but fails as if battery flat, but the headlights are bright - does this point to a knackered starter motor (solenoid or motor itself?), and could it also be shorting out here internally? I'm thinking of getting a replacement from the scrappy, but not if I'm wasting my cash. Anyone got any ideas?
Recharged battery.
