E EDW2000 Aug 21, 2018 #1 Is the cause likely to be the little silicone oval things under the scuttle? Mine are rotted, dealers says it cant get them in. ta
J jaydeen Aug 21, 2018 #2 Yup, that was the problem I had. I had to pry out the oval inserts, clean them up as best I could, then re-seat them using a good dollop of siicone plumbers sealant. I added a second dollop before I replaced the scuttle. Did the job for me. regards
nissan boy Aug 21, 2018 #4 There's two , a green one under the windscreen and a white clip both can let water in
