Water coolant pipe dimmensions
Hi to all! I have a leakage from water coolant of my K12 1.2 liters 2006. Some of you have any ideea if that water pipe with three directions is the same for all k12 engines? For example if i can fit amother pipe from another k12 but 1.4 liters engine? Thank you in advance!
May fit but would be wise to check it's the same type of system ie with or without aircon etc.
You're best option however, measure the pipe with digital caliper and replace with new for a longer lasting repair.
