V
VII
Guest
By the way lad's 4 stud VW Wheel's will fit the k10 I was at ATS having a stud replaced, and there was a vw wheel there. I ask the guy if it would fit he tried and it did. WOW mk1 golf GTi wheel for me.
SammoHung said:I think the centre bore of a VW is slightly too large 60mm?
The VW wheel goes over, but the studs take all of the load.
Normally with the propper wheel, the centre of the hub 59.1? takes the bulk of the load on the wheel, and the studs keep the wheel pressed tight against the centre of the hub.
I'm supprised the dude at ATS did not explain this.
Also, your 3rd party insurance cover may be void by using them..
Sorry to be a sad old killjoy, but I would get expert advice on this before using the VW sizes.
There you go, I take it that you've had it done then, how much did it set you back ?andrewb150 said:Secure the Wheel to the bed via the studs, then keep moving the bed until centred using a tool called a "clock".
A few beers and some food. Ok if you know the right people.sonic said:There you go, I take it that you've had it done then, how much did it set you back ?
THATS ME!!!!Demarest said:Didnt someone on here fit VW bottlecap style wheels on there micra?
