Various electrical issues?
Okay so going to list a few of the electrical issues i'm having, hopefully someone can shed some light.
Micra is a 1.3S
Issue #1
Dashboard clock works, but switches off then back on when you turn the ignition key to start the car, losing the time (it's always 1pm when i go for a drive!)
Issue #2
Rear wiper water pump has randomly stopped working entirely, all you hear is a faint 'click' when you attempt to use it.
Issue #3
Oil+Handbrake light stay on even with the handbrake off, it did this once in the past but changing the front brakes solved it for a few weeks - front brakes and rear shoes are virtually new, brake fluid is smack bang in the middle of mid and max, checked the handbrake switch and that's fine also. - i sort of suspect a grounding issue?
Any advice for the above would be well appreciated, as would a pinout for the dashboard electrics
