about 10 deg either side of tdc on overlap eh craig.Do you know what degrees that happens at Frank?
aye, the piston is 2/3rds the way down when the valve is fully open (so lift has nothing to do with p2v clearance eh)Cheers budI guess it will always bear near TDC and the plasticine test will tell you if you need to pocket or not - did you just leave your 1l pistons flat topped then?
my 1.0 piston 260/10mm setup had about 2mm mate, you probably would,nt need pockets till about 290 deg4mmgreat! do you know of anyone running a high compression unit with some fast road cams on top? hows the clearance after that??
that block looks decked dave ?Aye, no problems with 'fast road' cams.
You'll only have to worry about PTV contact if you build something exotic, which only a few are mad enough to do
Here's our pocketed pistons in our CGA lump....
not enough to warrant removing 2 links from the lower chain then daveJust a nat's #### to ensure a good surface Frank. Both myself and my engine builder consider decking in the general sense a no-no.
not enough to warrant removing 2 links from the lower chain then davei hope those pistons dont hit the quenchsteps ! (slightly proud aint they)
Waa, the pic doesn't work for me
They Matt Humphris pistons?
C+P works for me too, those pistons look very tasty indeed, care to share any details or is it all top secret?
Ta
Very nice indeed. Dare I ask for a rough cost and where you got them? Are you proceeding with a totally open deck?
Haven't asked the price of them yet. They were made by CP pistons and yes open deck, as that's all there is with a CGA.
