Baz
Ed-
Just wondering ever since I serviced the st over the weekend its had a small hesitation when the turbos in and the foots planted but when you have your foot say 3/4's the way down on the throttle she's fine.I think I may have upset some of the vacuam pipes connected to the inlet manifold when I had the rocker cover off adjusting the tappets.Now I have replaced alot of the vaccuam pipes as the ends of them were perished but not these as there in fair awkward position.Also sometimes it hunts as if its goin to cut out while idling and the vacuam on the gauge is closer to 0 than usual.this only happens sometimes otherwise idle is perfect
What do you suggest to look at.It feels like a misfire but I just changed the plugs,leads and distributor cap
