Unknown offset...
MicraPRO
Part Of The Furniture
I'm confused... as some of you will know I've been running cheapie gold wheels for a while and after fitting new brakes today I realised that they simply have to go... As I've really taken a fancy to lenso rs5's
When I bought the gold wheels I didn't check offset I just put them on went for a drive with no rubbing and bought them.
After having a look today all they say is 7Jx15H2
Does anyone know what kind of code the offset is written in? As there are others but nothing that looks remotely like a offset figure... As I'd like as much of a straight fit with my new wheels...
Don't know if I'm being stupid of not.
Thanks Tom.
Offset is the distance between the center line of the wheel and the hub face in mm.
So ur alloy is 7" wide, centre is 3.5" = 89mm
Measure from hub face to the inside lip of wheel, subtract 89mm to find ur offset.
Usually marked like "ET40"
Thanks I'll try and work this out today.
