hi there was wondering if it is possibale for the k10 ma12 engine will flow a t70 xs power turbo, it has a very big diam of 70mm on the exhaust end, started to open up the exhaust ports on the cylinder head to 35mm, but dont think it would be possibale to put 35mm exhaust vavles, in as the inlet would be the same and they would hit on overlap, hoping to run it on a set of bike carbs, want to use the conrods and pistons out of the k11 1.0 as they a 71mm bore but sroke is smaller so compression would be lower and engine should rev more higher, hope to make 300bhp is the possiable i think it can be if you can get 1500bhp out of a 1500cc f1 engine. any tips would be helpfull thanks kev (Y)
