Tow Bar
jonpw
Hi guys!
Does anyone know of a guide anywhere to fit a K11 with a tow bar? I have seen them about with them on but have had a look under the back and can not see anywhere where one might go? Anyone got any tips or anything?
Thanks!
i have had a towbar on 3 of my micras, there is no guide, one fitted by bolting through the side of the chassis, one bolted through the top and bottom of the chassis, and the same one needed new holes drilling to fit to my March. so you need to get a towbar and see how it fits.
Have a look on the Witter site. There are two PDF downloads on how to fit them. Basically its rear wheels on ramps, rear bumper off and a small cut out of the bottom, silencer off to give access too. Mine went well and its easy. The two types of fitting in the box chassis can I think be used on either car. I think the fittings changed according to where the holes are drilled in the chassis box section by Nissan. Drill your own if they differ.
Use googles when under the car as lots of dirt will be falling off as you work.
Good luck
Nigel
