J jk9194 Feb 1, 2013 #1 i am going to change new drive belt, alternator belt and water pump soon. are these two pulleys' ok? cos i am thinking to change new two pulleys' if these belts and water pump are ok to run then i wont change these two pulleys' thanks jk
frank Club Member Feb 1, 2013 #2 the pulley,s will outlast the car jk, just remove 1 belt then listen, then remove the other belt and listen
OP OP J jk9194 Feb 1, 2013 #3 frank said: the pulley,s will outlast the car jk, just remove 1 belt then listen, then remove the other belt and listen Click to expand... ok thanks frank
