Those early K11 hub caps - Standard wheel-nuts...?
Can someone confirm that the little 190mm dia hub caps fitted to the early K11 fit onto 21mm AF nuts fitted as standard on my 02 Micra.
I always liked them so I bought a set of these caps off ebay and they seem a really tight fit.
Also if anyone's got a spare 190mm cap knocking about I'll take it off your hands for a reasonable price as one of mine is damaged.
They will fit as the stud pattern and nuts are the same on all k11 micras.
They are supposed to be a tight fit, otherwise they would fall off.
You have to give them a decent few whacks with the palm of your hand.
Do you have 14" steelies on your '52 k11? If so how well do they fit after you've wacked 'em on. As in do they fit as they would on 13s, or is there a small gap or anything? Pics?
Yep 14". There are no gaps that I can see, I've not permanently fitted the covers yet as the wheels are still in their epoxy primer but they seem to fit the radius as intended.
I might post a pic when they're all painted and finished
