Think ive got a dodgy one
Hi all , my micra (m reg k11) has a problem ,when I come to start it , sometimes it will start ,fire up but cut out straight away and when I go over harsh bumps it cuts out or even when im just drivin around it will cut out , any help would be greatly appreciated , ignition switch maybe ?
I got same problem with you so I haven't solve this problem yet. It's so annoy you know. It happens to me in every mornings or if you leave your car on the road for too long time.
So far, I changed new alternator belt and new key.
The next job will be change new battery clamps, water pump and water pump's drive belt.
Really? I do remember that I got loose negative battery clamp. I can't tight it properly so I need to get a new battery clamp.
A loose fuse is not uncommon, or one that separates and reconnects. Had that on a Honda prelude, it took the garage 3 days to find it!!!!
Checked pretty much everythin ,if it was dizzy or any thing to do with the ignition wouldnt ignition lights come on when it cuts out ?
