these gti almera wheels
Hi lad's wonder if you's can shed some light to this question please (did a search but nothing to answer question) got a set of gti almera wheels with 195/45's on them now looking at a web page that show fiterment of cars it say almera bore is 66.1 and a micra is 59.1 so do i need sigot rings to make said wheel fit this is on a k11 preface lift 98 (R)..reg
thanks for listening
tony(Y)
I have a set on my k11 without spigot rings and have had no problems ,I have 195/50x15 on front and 205/50x 15 tyres on the rear.I hope this helps-I have suffered a little balance problem at around 70mph which has not been cured by wheel balnc ing so it could be down to the lack of spigot rings-Jon
So in a nuts shell i need spigot rings to put these wheels on next question is where do i get them from?
thanks lads for info
tone
You should be able to get them in Halfords or similar but from experience I would go to an ally wheel specialist who knows what they are about ,often places like halfords/motorworld sell wheels and fixings but have no clue what they or you are talking about-Jon
internal bore seems ok you will have to measure inside of alloy wheels & compare to outside measurement listed on e-bay they list around 76mm which sounds too large-Jon
this is a lot of mucking about i think i sell the wheels and get brand new wheels with fitting kits anyhow big thxs mate for the help and advice
tone
x3
And if you do get a bit of a vibration turn the offending wheel round 90 degrees on the studs and give it another go. Oh and be carefull to tighten the nuts up in sequence (opposites, to stop the wheel being pulled off center).
