Been looking hard to find a solution to fitting my tachometer. I currently own a k11 1.0l Facelift '00 trying to fit a tachometer. Have tried 3 different wires from behind the instrument panel but none are giving me the correct signal. Have tried blue/black, green/white, and green/black none of which are giving any kind of signal. The tachometer itself is all set up correctly e.g. cylinder readings and power/illumination. Just hoping someone on here who knows more than I do can help out.
EDIT: I've also had a look at the cabling on the coilpack but id have no idea which one or where to pull the signal from.
