sway bar kit
D
drpepper970
thinking about buying this for my 1.3SR as i've read that it really improves the handling, where can you get them from in the UK and how much does it cost?
Had a look at Whiteline UK site and there price guide is in ozzy dollars and is 3 years old!
is a strut brace also worth fitting or is difference negligable on top of the sway bar kit?
Look at how close the strut tops are to the firewall.. Yes it will make a difference but not as much as say a strut brace on an Almera.
Swaybar - yes definate improvement. Have a search on this site as there's places to get it much easier than whiteline. Also I'm not a fan of just replacing the micra's rear swaybar. I think it makes the car a little bit unbalanced (i've tried it before myself and put the original rear swaybar back on until I can afford the replacement front item as well). Replacing the front and rear at the same time makes for more balanced handling.
