Suspension squeaking noise
CMF_Lodo75
Hi, my suspension makes an annoying squeaking noise. It does this in all the situations, so when my steering is straight and both wheels go up- and down at the same time. Or one wheel first while steering. I’ve already put some lube in the silent blocks at the rear of the arm, my shocks are brand new. Only the front bushing I could not really lubricate. Is this the cause?? I also put some lube between the sway-bar rubber mounts. But still it squeaks. Anyone know how I can fix this?? Thnx greetz
CMF_Pierce
Hey mate,
A really common squeaker is one of the engine mounts (though I can't remember which one). Somebody on here must know but I think a quick search for squeaks and suspension noise will answer most of your questions ;)
Just remember, If you've chosen nolothane performance mounts and bushes, squeaking is part of the package unfortunately.
