I have a clutch that is giving me some concern and would be interested to know if anyone has had the same problem.It is not slipping at all, but does give off a loud screatch as you depress the pedal slightly. When pressed further or disingaged the thrust bearing seems quiet. Also the travel passes through a stiff point at almost its limit which can cause control to be difficult when menovering in tight spaces. I realise it's not a big job to replace a clutch, Hovever, I would be interested to know How long before this becomes nessisary ?
