porkpie700
Buy & Sell Member
I have been planning this restoration for years, and after three months i'm almost at the half-way point.
The goal is to fully restore my Super S (with subtle modifications) and power it with a modified MA12, running on the March Turbo/Figaro ECCS turbo system.
Presently i'm just a few weeks away from the bodywork and paint stage.
So step 1 - obtain a Figaro for this project.
Strip-down
RUST REPAIR!!!
Bare-metal restoration was necessary to eliminate the many tiny rust spots dotted around the body.
I use Zinc spray rather than primer, to protect the metal until the car is resprayed properly.
Chop out the rot, treat the wound and rebuild.
The same back-to-bare-metal treament was carried out underneath the car too.
Small modification to help reduce under-bonnet temperatures. This will direct cool air directly onto the exhaust manifold and turbocharger.
The ventilation hole is reinforced with a right-angled steel frame to prevent bonnet flex. Rivet nuts were also fitted so that mesh can be bolted into place under the vent hole to help diffuse the air as it enters.
Engine bay needed rust-repair along with a few additional, reinforcing welds along the seams and suspention strut mounts for good measure. These will be blended-in and coated with seam-sealer to match the origional "factory look". Crossmember and "slam-panel" were also taken to bare metal and treated.
Moving around the the other side...
Strip-down
RUST REPAIR!!!
