As some of you may know, I've been looking into putting the super s fogs/driving lights/whatever you call em thingy's in the super s bumper I got a while back off alienfish.....
Anywhoo, I've got some now and finally got around to fitting them. Managed to fix them into the bumper ok with a bit of effort and had a look at connecting them up.
So had a look at the fuse box, relays, wiring, etc and it turned out that I have the fuse,wiring and connector all ready to plug in, just needed a relay (maybe its cos mine is the LX model, not sure if all K11's had all that stuff ready to connect fogs??)
Purchased & fitted a relay and plugged in the drivers side light to the connector just behind the washer expansion tube & it works fine.
Problem is, I'm ######ed if I can find the passenger side connector. Spent an hour looking for one on the car and searching the MSC threads and couldn't find it, or anyone who found one.....
So my question is, where is it? and if there isn't one, do I need to just splice the passenger side fog into the wiring for the (connected) drivers side one? And if I do need to, how/wheres best to do it??
Would hate to have done all this work to only have one of the lights working :down:
Cheers.
Cheers.
