sub in my k10
iv just finished wiring my sub and it is crackling lots when i turn it on. dont know whats causing it. any ideas?
Please post in correct section
damaged phono leads
poor earth contact
leads not plugged in correctly
gain is too high on the amp, and too low on the cd player.
But most likely the 1st one. As its sounds like your getting interferance.
like the guys have said power leads on a seperate side to the rca cables found the left side was best for power as its the battery side :) all i get is a pop when i turn the stereo on and off and when i brake and when i put it into reverse.... im thinking earthing for that one?
have you run the RCA cables next to the power cable? should run them down the other side of the car really i think.
yh iv got the power cable on the other side to my aux leads and my remote wire, ill move my negative lead and find a cleaner connection,
will post if if works or not
