stupid question
as above, the only problems you will get will be the radio and the clock. everything else will be fine. the car is no good if every time you want to do a simple thing like change the battery, you have to take it to nissan to be reset.
Took Mine Off For A Few Hours To Mod The Air Filter, When I Hooked It Back Up The Traction Control Light And Skid Light Were On. Car Ran Fine So Went A Blast And It Put Them Out, Good Job.
just radio code needed, if original radio fitted and you lost your code then email me with the serial number and i will send you the correct code, serial code should start with BP
