strut brace
would of thought so, as its basically the same car but with different engine setups...the mounting points should be the same.
yes a nova brace will fit but you will need to drill new holes to fit it which TBH isnt hard at all, other than that it should be a direct fit from what im told
Most braces would fit with altering. Shorten or lenghen the bar and redrill the holes, just make sure its sits properley on top of the suspension arms otherwise it'l be useless.
nova braces are already the correct length i would recommend a nova or k11 brace they are cheap and easy to get of ebay ;) dont waste time making others fit
