I'm pretty sure it was only autos that had the closed deck, your best bet is to ask Frank seeing as he has more experience with them![]()
yes, and its been covered enough times fwn
Sweet, I'd thank you all for your input but can't do it on tapatalk app![]()
Although I did find some pics to explain the engine to methe extra rib at the top etc.... Posted by frank no less lol!
Pepper
It's a shame turbo-ing is such a money pit.
Sean; said:THEORETICALLY the uk block with the closed deck is stronger therefore better for turbocharged/supercharged/high compression applications however in PRACTICE it seems there is no real worry to have as the Jap spec open block is holding up great in a number of turbocharged and worked cars.
Even if cylinder warping occurs butresses can made up which sit between the exterior bore wall and the block to support and stop the cylinders warping.
Standard block will be fine, no-one on this forum is pushing the engines anywhere near hard enough to have any issues.
How hard will I need to go for the engine change to be worthwhile? I was planning a 5psi build BUT I might do a 10psi or even a bar depending on ECU restraints as I dont know when Nistune or Emangage will need replacing if they ever will of course.
So yeah I might over engineer my build for reliability and "just because I want to" reasons.
Thanks Pepper
Nothing wrong with over engineering things a little, at the end of the day it's your peace of mind and what you are happy with doing
FYI, both Jim-GR and Nis have turbocharged the CGA3 which are open deck and they are both pusing 220bhp, Jim-GR probably more. Last I saw he was running somewhere around 1.7bar boost and revving to 7000rpm+.
105k is nothing dude, we had one up to 187k and that little rocket got plenty of spanking.
They both have uprated low compression pistons right? So my real weak spot will not be block but pistons/rods? Head gasket etc?
What head gasket would be best? A standard one or will I need a special one?
Thanks Pepper
Factually though, I believe polly is the best point of contact as he's given his car plenty of stick on tracks etc. So before saying any more, (as honestly I am an N/A man still), I would have a dig through his blog and/or shoot Pollyp a PM and ask him. With everything he's done to his car so far he should be able to give you an honest answer![]()
I've read every post in Polly's build and I know he uses the standard engine at 10psi but he had a forged engine too that didn't work out for him so it throws up more questions lol
Thanks for all the input guys![]()
Pepper
heya
yep i'm using my grey micras original engine (it was an auto so its a closed deck block), with a normal multilayer HG and 10psi boost.
been to afew tracks and runs tip top.
one time when my wastegate line severed, it briefly went upto 20psi and it was still intact.
the forged piston engine was just over-bored wayy too much so the rings leaked badly from the beginning. new block is getting remachined n balanced as we speak.
HG that came with the forged engine blew cos it was a cheapo soft composite type that breaks apart easily. replacing with a MLS gasket which don't break apart fixed it.
Where did you get an MLS gasket for the K11 from polly?
I asked him the same question, he said "Can get em from nissan dealers or engine parts store bout £50-£80. Avoid them cheap £30 eBay hg"
Hope he doesn't mind me quoting him
Pepper
