Stiff Suspension
r-reg-sr
Site Supporter
micra adaptable corsa b set up £100 plus post.
and says it in the title improves the carting experience with plenty of G-force.:)
lower or raise your car gives different size wheel options.
with this you can truly say I'd had a stiff one.
i won't knock it for its tyre thread shredding cornering capabilities.
I was thinking of a set for mines, I need to make my ride higher, will this make it lower and higher, from stock Micra I want about 20 mm drop only ?
only difference is you would say "that be a stiff one" after rocking with this set.
these are front height adjustable with rear needing standard spring adjustment to lower.
So am I better getting lowering springs only then?
springs for you and should be slightly stiffer at 20mm.
you could try these. have a search on here how to fit.
I could but then it wouldn't be set. have you looked into standard corsa rear shocks from the same year ? they short like this but less stiff.
Sorry going back on stock springs again theses will make it too low as I can't have it that lower, so up for grab just
